Yes more than enough regards forces etc but has pointed out by neale 20mm can work better regards spacing etc. Personally I use 20mm on all axis for simplicity and hardly any difference in price.
Yes you need more bracing to stop deflection. 5mm steel isn't really upto to it without being braced.
20-11-2015 #2
I have 15mm rails on Z and they work ok but they use M3 bolts on the rail and carriages which look very small compared to M5 on the 20mm rails on my Y axis. When cutting I can feel vibration across them especially the top ones and for this type of machine I would go with 20mm on Z.
30-12-2015 #3
Hmm maybe I will stick with one motor and use a single large belt. I don't think it will require much modification (whilst still having the potential to run 2 motors in the future). Just need to make sure I can tension the belt well. I'm thinking of a simple idler pulley which I can slide in a slot.
30-12-2015 #4..Clive
30-12-2015 #5
30-12-2015 #6
You don't need to spend money on pulleys just to use them as tensioners.
30-12-2015 #7
What ability have you got for machining the aluminium? If only basic tools like me then you could probably lose some of the pockets. Would help with adjustment later too ?
30-12-2015 #8
01-01-2016 #9
01-01-2016 #10
The spec. for HTD belts say make sure to have 5 teeth engaged. This is based on ensuring that with a sufficiently high load, the belt will snap instead of the teeth ripping off. This hardly matters to us, as we're not using the belts at close to their load ratings, however we do want to get good stiffness from the belts (especially with such a long best) so it seems a reasonable baseline to design for at least 5 teeth engaged.
The Following User Says Thank You to Jonathan For This Useful Post:
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
