10-07-2014 #11
The significant advantage from putting the rails one the top and front of the top and bottom beams respectively (as Jazz suggested earlier), is that you can make the rails a bit longer and thus increase the spacing of the bearing blocks a bit without widening the machine or loosing travel. I'd certainly recommend that since the stiffness due to the bearings is proportional to the bearing spacing squared (assuming what they're mounted to is rigid etc), so every little helps.
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
