18-11-2015 #11
If using typical router setup with 10mm pitch screws and steppers then you don't have a ratio so it's 1:1.
Common pulley size is 20T. Don't go too small because there's not enough teeth engaged. Don't go too large because you increase screw inertia which affects acceleration and power required.
The main reason for using pulleys is to lessen resonance which affects steppers. The abilty to apply a ratio is just a bonus.
One advantage if usng say 10mm pitch is that you could apply 2:1 ratio and increase torque and resolution if ever required. Or go other way and apply ratio if you ever needed more speed but with 10mm pitch you won't anyway thats why 1:1 ratio is often used.
Same with Z axis keep 1:1 ratio but use a 5mm pitch screw for better resolution/torque.Last edited by JAZZCNC; 18-11-2015 at 10:07 PM.
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
