    Your machine looks great, thanks for all the advice.
    I've increased the plate width to 170mm now. The z rail centres are 118mm apart at the moment. Do you think the carriages need to be separated more in the z axis? (They are 119mm centres) I'm trying to reduce this length as much as possible in order to reduce the total height of the z axis plate (if that makes sense.
    Also, is it worthwhile pocketing the carriages slightly like I've done elsewhere?
  1. aluminium profile for cutting bed of router
  2. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 02:01 AM
  3. Multiple CNC Opportunities both Nationally and Internationally
    By cnc jobs in forum Opportunities Available & Sought
    Last Post: 21-09-2012, 01:01 AM
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
