29-01-2016 #191
30-01-2016 #192
More big steps today...cleared a big space in the shed and measured up ready to build my workbench/stand!
On a side note, what method does everyone recommend for finishing aluminium parts? Some of the larger parts I had machined for my router are not milled on both sides and so are dull and have the original "stock" finish (some have lettering etc). I want a finish which is durable and ideally helps oxidising. Anodising would be ideal but I think that's going to be a little price and not something I can do myself? So this leaves me with: Polishing (if so, what's the best way and will the finish oxidise over time?), spray painting, powder coating, other plating??
Thanks in advance!
30-01-2016 #193
It's bloody tool not a Pimp My Ride.!. . .
. . . . . . Which is bit rich coming from a Bloke who's spent quarter the day Plastic coating parts for sexy little router he's finishing off. . .
30-01-2016 #194
30-01-2016 #195
I've polished a few bits of aluminium by starting with about 220 grit and a random orbit sander then going up the grits as high as possible before finishing by hand. I don't really think it's worth it though as aluminium is so soft it scratches again in five minutes. I suppose you could spray a lacquer on it maybe.
30-01-2016 #196
Hmm I think I'll do a 'quick' polish but nothing overboard.
While I'm thinking about it, should I be using threadlock on all my parts? Or will torquing to the correct value be enough?
Also, do I need to remove all the machine oil from my new ballscrews before using them?
04-02-2016 #197
Ahhhhh panic!!!
I thought things were going too well... I don't know how I've missed this but the 45 series rexroth extrusion has 10mm diameter holes for M12 screws on the ends. For some unknown reason I've designed my aluminium gantry sides for M6!!! I've seen you can get an M8 "cutting bush" which reduces the bore. Would my best option be to use these and get the side plates drilled out to M8?
05-02-2016 #198
05-02-2016 #199
05-02-2016 #200
What plate thickness have you got?
There are currently 14 users browsing this thread. (0 members and 14 guests)
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
