I've polished a few bits of aluminium by starting with about 220 grit and a random orbit sander then going up the grits as high as possible before finishing by hand. I don't really think it's worth it though as aluminium is so soft it scratches again in five minutes. I suppose you could spray a lacquer on it maybe.
30-01-2016 #2
Hmm I think I'll do a 'quick' polish but nothing overboard.
While I'm thinking about it, should I be using threadlock on all my parts? Or will torquing to the correct value be enough?
Also, do I need to remove all the machine oil from my new ballscrews before using them?
04-02-2016 #3
Ahhhhh panic!!!
I thought things were going too well... I don't know how I've missed this but the 45 series rexroth extrusion has 10mm diameter holes for M12 screws on the ends. For some unknown reason I've designed my aluminium gantry sides for M6!!! I've seen you can get an M8 "cutting bush" which reduces the bore. Would my best option be to use these and get the side plates drilled out to M8?
05-02-2016 #4
05-02-2016 #5
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
