Yes I found that. I bought my m12 from arc euro and a set of Ruko m3-m10 on eBay but only because I spotted a good deal, can be quite pricy otherwise.
10-02-2016 #2
Think I have the bolt problem sorted now...will update soon. Now on to the next problem...
I was playing with my ball...screws last night before bed ;) I've noticed that the Z-axis ballnut (RM1605-C7) seems a little notchy and not smooth. As if there could be some swarf or something inside? The ballscrews are covered in a light machine oil (I assume to prevent oxidisation). Do I needto strip down and clean everything before use? Do the ballnuts require greasing first?
On a similar note, is there any specific preparation I need to do to my linear rails/bearings before use? (I need to assemble the HIWIN ones).
Cheers,
Dave
10-02-2016 #3
On my HiWin, I followed the manual, I used light grease and worked it in slowly by running the carriage up and down by hand and giving a little grease each time, this is done on the rail of course ;)
15-02-2016 #4
Hi all,
More progress has been made and my bank account is starting to hurt! I sorted the bolt problem, counter-bored the plate for M10 socket caps and then heli-coiled the extrusion to match.
I am taking photos as I go so I think I will do a big dump of information in one go rather than little updates every so often.
I have started to really think more about swarf and coolant removal during/after machining. Hopefully the paint diagram below will help explain what I'm thinking about doing. The gap will allow me to brush swarf straight off and into a bucket under the bench. Would the proposed design weaken the frame too much?
EDIT: Infact, could I even remove that extrusion completely or is it going to put too much outwards pressure on the sides?
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
