12-03-2016 #11
If the ballscrews are bent then you will get a periodic tightening as you rotate it, especially at either end of travel.
If the ballscrews / mounts / nuts are all mis-aligned then it will have a constant tightening at either / both ends.
Assuming the ballscrew is fairly straight then looking at the design the ballscrew supports and ballnut bracket are probably not completely in line. It doesn't look like you can adjust in the plane away from the sides of the machine, only up and down.
Try moving the machine to the driven end, loosen the 6 bolts holding the ballnut to the ballnut bracket, and remove the floating end bearing. This should allow the ballnut to sit in an unloaded position.
Nip the bolts back up and move the gantry over to the other end. Gently slide the floating bearing back on - it should sit snug onto the mounting block on the side of the gantry. If it is out, fit a shim. If it is tight you need to machine a bit off the mounting block.
Tramming is related to getting the spindle motor normal to the bed so that the side of the cuts are 90deg to the top surface. You can get close by putting a bar in the spindle and using an engineers square to check the spindle is 90deg to the surface on all sides / angles. You can also get a twin DTI block which gives a much better indication of tram condition. Have a read . . .
http://www.cnccookbook.com/CCMillTramming.htmlLast edited by routercnc; 12-03-2016 at 10:52 PM.
The Following 3 Users Say Thank You to routercnc For This Useful Post:
There are currently 12 users browsing this thread. (0 members and 12 guests)
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
