Page 26 of 28 FirstFirst ... 162425262728 LastLast
  1. Quote Originally Posted by biketrialsdave View Post
    I'm getting very close to finishing....watch this space!
    Any news?!
  2. #252
    Oh so close! I have movement, all sensors working with mach 3 etc. Just need a spindle and I should be there. Got some slight crunching noise to sort out on one of the ballscrews. Only happens near the end of travel so I suspect it's an alignment issue?
  3. Looking good! And very close to a finished machine. Nice one!
  4. #254
    First cuts on a piece of old plywood!
  5. #255
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    https://youtu.be/rnGz0vA8aEI
    Its always nice to see a new machine doing its first cuts. Sounds nice as well.
  7. #256
    Lovely looking machine Dave well done mate.
    One question why is the spindle so high up the front plate.?
    One suggestion.!! . . .Cut deeper.
    That cut could have been done in one pass and much quicker. Know there your first cuts and probably think it's better or safer cutting shallow but your more likely to knacker the tool and snap it cutting shallow due it over heating the tool.
  9. #257
    Very nice, looks a sturdy little machine there.
  10. The Following User Says Thank You to Davek0974 For This Useful Post:
  11. #258
    The spindle could really do with being lower, I agree. I wish I designed in more Z clearance height though! (Let that be a lesson to anyone designing a machine at the moment).
    Your right about me being conservative. I'm now on a steep learning curve with feeds and speeds, in fact CAM in general. I was a bit naive thinking CAM would be the easy bit! Thanks for all the help yourself and the rest of the forum have given me; I feel this is only the beginning!...
  12. #259
    Has anyone used one of these two piece vices before? Only 75mm total height which would help me.
    http://www.arceurotrade.co.uk/Catalo...Milling-Vice-6
  13. #260
    Can't help with the vise but CAM is certainly the hardest part of the process ;)
    I spend most of my non-machine time at the CAM stage, figuring out out how to do stuff and not break the machine or the tool. Dodging clamps is my current lesson;)
  1. aluminium profile for cutting bed of router
  2. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 02:01 AM
  3. Multiple CNC Opportunities both Nationally and Internationally
    By cnc jobs in forum Opportunities Available & Sought
    Last Post: 21-09-2012, 01:01 AM
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
