07-08-2014 #101
Not touched the mechanical design for a while as I got distracted down the route of designing my own stepper driver...
So here's a small update. I'm feeling quite bad for how much this is looking like one of JAZZ's machines! Believe it or not I am not trying to copy you Clive!
I am still not happy with the way I have the Y axis plates attached to the steel box section. Think I need to come up with something better?...
07-08-2014 #103
Oops! I meant Dean...it's been a long day.
Nice machine though! :)
09-08-2014 #104
11-08-2014 #106
I think the end is nearly in sight!!
All steel plate is currently 3mm ("Y axis "end stops" and end plate attaching bed), should I make this thicker? Will there be any problems welding it to 3mm thick box section? I have a friend who works at a laser cutting place so I'm hoping to get those pieces cut there.
05-09-2014 #107
Any comments on the above would be appreciated =) I think I need to start looking at places to get the aluminium milled soon!
I've been a bit distracted with designing my own stepper drivers but going to put that to the side until I have the mechanical design all done.Last edited by biketrialsdave; 05-09-2014 at 01:32 PM.
05-09-2014 #108
06-10-2014 #109
Thanks for the input Eddy!
Well it's been a long time since my last post and since then there have been some large changes... Now, I am fully awaiting the groans and face palms when I say this....
I have decided to return to using aluminium profile for the frame. The reasons being:
1) My welding skills are not quite there. They aren't bad but I envisage a lot of trouble trying to get things square and aligned correctly.
2) I now have free access to a water jet which I plan to cut beefy steel brackets from to connect the profile together with.
3) I have re-evaluated what I will mainly be realistically cutting and steel may be OTT!
Anyway, enough excuses. Here's the latest design. I would really like to get the ball rolling with the custom aluminium parts. Am I best posting on the job request page and going from there?
Dave
12-10-2014 #110
Job request can be found here: http://www.mycncuk.com/threads/7974-...-my-CNC-router
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
but I don't see the resemblance to mine if it is me you are referring too. ..Clive
