Page 12 of 28 FirstFirst ... 2101112131422 ... LastLast
  1. #111
    I really need to pick this project back up! Been having some thoughts recently and have come to the realisation that what I really need is a machine capable of cutting aluminium more than anything else. I'd really like to mill enclosures for my many electronics projects. Perhaps I need a re-think on the complete design!
  2. #112
    Quote Originally Posted by biketrialsdave View Post
    The design you had wasn't too far away from cutting aluminium. It could benefit from a better/stronger base and the the linear stage for the Z axis isn't really up to aluminium but the general layout of high sides with gantry sat on rails is perfect for aluminium. Gantry design is nice and strong enough for aluminium.
    If you sat that lot on nice piece of machine tooling plate or better still Granite base the frame would be sound for aluminum. Ditch the linear stage and put a conventional Z axis with decent rails etc and your sorted.
  3. #113
    Some encouraging words there, thanks Jazz! When you say "sit the lot on machine tooling plate or granite..." which bit are you referring to?
  4. #114
    Your design doesn't show any base and looks like it sits directly on table.? So I mean put EVERYTHING on solid flat foundation.
  5. #115
    Ahh I see, yes your right. I'm not 100% happy with the useable z height I get either. I think I will redesign the z axis but may also have to increase the height of the gantry sides. I could do with finding a 'cheap' solid solution for the bed too...
  6. #116
    Not sure if to consider coolant at this point either!
  7. #117
    Yes 100% consider it and also cable routing etc.
    Cutting aluminium correctly will need a minimum of blown air and idealy minimum qty coolant ie: Fogless mister. Don't need full flood but better if can have it.
  8. #118
    I think an aluminium bed with t-track bolted to it looks like a good idea. Just need to find some for a reasonable cost!
  9. #119
    I may of found a cheaper solution. "MakerBeam" is a 10x10mm extrusion and relatively cheap. I was thinking something along the lines of this:
Name:	Bed Beams.JPG
Name:	Bed Beams2.JPG
    For the bed plate itself (shown in green). What would be the most cost-effective solution? The dimensions are 725x825mm. Steel or aluminium? What thickness would suffice?
  10. #120
    I might of solved my bed problems! Look what I found in the skip at work today (along with other goodies)... It's 6mm steel plate. The dimensions are perfect for the machine to sit on. The raised area in the middle also looks perfect for mounting a bed (aluminium plate or t-slot plate perhaps?). My only concern is how flat and level the plate is. I was thinking it doesn't matter too much if I skim the aluminium plate (or whatever) with the machine once it's built?Click image for larger version.
  1. aluminium profile for cutting bed of router
  2. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 02:01 AM
  3. Multiple CNC Opportunities both Nationally and Internationally
    By cnc jobs in forum Opportunities Available & Sought
    Last Post: 21-09-2012, 01:01 AM
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
