No the other way round lol, from what I understand there is no standard but on this forum they refer to the X axis as the back & forward axis, (longest axis on you build) & the Y axis as the left & right movement. Z is as you have it up & down.
Reason for the twin ballscrews is to prevent the gantry from twisting as it moves backwards & forwards.Last edited by martin54; 04-01-2013 at 08:35 PM.
05-01-2013 #2
Depends if you view machine from front or side. Really your just using the Cartesian coordinate system which is X Axis horizontal or left/right and Y Vertical or Forward/backwards.
If you stand in front of machine like milling machines user's do then the moving table is X axis and it goes Left/right and Y axis goes away and towards you.
Router users often load and stand at the side of machine which is often the longest Axis. So setup machine to work from the side and match the coordinate system of left/right is the X axis and again the y axis goes away and towards you along the gantry.
When I first put my machine vertical the hardest part or strangest part was getting my head around the fact it was still setup to be used and viewed from side and know I was stood in front of it. Kept thinking the code was wrong because I was expecting it to move L & R for X when it went UP/down instead.?? Very confusing.!! For it all to make sense all I had to do was tip my head to the side and things looked right.!
To match the CAD/CAM coordinate system and still look right in Mach I should set it up so that the X axis runs along the gantry left/right and the Y axis vertical Up/down.
I haven't done it yet but I should really has it's a simple has swapping the motor inputs so X axis uses the Y axis input and vise versa.
05-01-2013 #3
There is the american standard the english standard and the european standard, I just Clasify them as they are said, X-Y-Z X is connected to Y and Y is connected to Z On gantry mills But my Boxford is a moving Bed from left to right so that is Y is connected to X and X is connected to Z.. That will throw a spanner in the works LOL
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
