I was meaning aluminium box section, you can get some really large sizes if you shop around. It's more expensive than a frame made from steel box sections but it's easy to work with and the supplier will cut it to length normally (I used aluminium warehouse iirc).
My first CNC design included a steel frame and I actually rushed out and bought a halfway decent MIG welder. I never actually built the frame in the end though, doh! Anyway, you don't need a fancy MIG to weld the steel frame together - a cheap and nasty stick welder from ebay will do the job, there's one up for £26 at the moment. The trouble with MIG is unless you go for one with some grunt it won't handle the 4mm thick box you'd want to build the frame from. As for keeping it square and level if you look around you'd be amazed what can be done with epoxy resin. Basically you weld up the frame as square as you can (lots of small welds + clamps) and then pour very thin epoxy over where you'll mount the x-axis rails. The epoxy will self level and should leave you with two sides that are in exactly the same plane. Check out this thread as Neil will be doing another epoxy pour any time soon (actually the technique in the first pour was fine he just fluffed the mixture).
06-07-2014 #2
Dave don't be fooled into thinking profile is flat or level because it often isn't and to make this worse your design makes it so your pretty much guaranteed you'll have issues with the rails binding.? . . .Your relying completely on the quality of cut on those uprights to keep the rails aligned and 90deg to the base. The 90Deg brackets are not accurate enough or strong enough to hold everything square. The fact your using 45x90 orientated in it's narrow section when the Y axis forces will be trying to rock the profile doesn't help and this is compounded by the fact the 90deg brackets don't hold it in that direction either.
Sorry to say this but while you think the frame is strong it's actually weaker than you think because it's not braced or held the directions that matter and your under sizing the profile. To make profile work for this design you'll need 90x90 for all the base and much more bracing in correct locations using plates not those poxy 90deg brackets.
For this reason Steel is much cheaper, stronger and more accurate if used with the epoxy method.
06-07-2014 #3
Hmm maybe it's time for yet another re-think then...
I don't want to go OTT with the design but obviously it needs to be useful. What are you opinions on the gantry design as it stands so far? Are there any other alternatives to a steel box section base?
Thanks for all the help,
Dave
06-07-2014 #4
Dave don't get me wrong I'm not saying profile won't work because it works great and I use it all the time but it does need to be supported and braced correctly and by this I mean not using in the normal manner profile is used IE: using corner brackets etc. I'm also not saying your design is flimsy or weak just not has strong as you may be thinking. It will certainly have some chatter in harder materials as the frame vibrates.
For this high side design to work best with profile, esp when on it's thin edge you need to brace the hell out of it using plates.
Your gantry is ok-ish but I would have a bit more strength in the bottom profile as this takes the most the cutting forces. To be honest I'd have the L shape layout of the profile at the bottom but with lower profile laid flat.
I understand your reluctance to weld but it really isn't difficult or needs to be expensive. Don't need a Mig and like as been said cheap stick will work fine.
If you don't want to weld then how about finding someone who can weld and have them do it for you.? If you cut and preped all the steel it wouldn't take someone long to weld that simple frame.! . . 2 hours Max and I'm allowing for a very very slow welder there.!! If all steel was cut and preped it would literially take me 30-40mins tops just for the welding.Last edited by JAZZCNC; 06-07-2014 at 11:32 AM.
06-07-2014 #5
Hmm well I do have an arc welder somewhere in the shed. Not touched it for years and was never any good at it! May need to get practicing...
06-07-2014 #6
Get it out and get practicing. Don't use old rods and buy good quality rods not some cheap rubbish from car boot as they make all the difference. Keep them dry and stick in oven on low heat for 15 minutes before starting. Welding new metal like Box section is a piece of piss with a stick welder. Also Just realise you don't need Xray quality welds and Just like Snow makes every body's gardens look the same so does a good grinder and paint on pigeon shit welds. . .
06-07-2014 #7
Just pulled it out the garage, its the one in the link below. Very cheap and cheerful. Only a 100A output.. What sort of thickness steel box section would be best to use? 3/4mm?
http://www.metals4u.co.uk/welding/we...sp?prd_id=3124Last edited by biketrialsdave; 06-07-2014 at 07:11 PM.
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
