Hmm well I do have an arc welder somewhere in the shed. Not touched it for years and was never any good at it! May need to get practicing...
06-07-2014 #2
Get it out and get practicing. Don't use old rods and buy good quality rods not some cheap rubbish from car boot as they make all the difference. Keep them dry and stick in oven on low heat for 15 minutes before starting. Welding new metal like Box section is a piece of piss with a stick welder. Also Just realise you don't need Xray quality welds and Just like Snow makes every body's gardens look the same so does a good grinder and paint on pigeon shit welds. . .
06-07-2014 #3
Just pulled it out the garage, its the one in the link below. Very cheap and cheerful. Only a 100A output.. What sort of thickness steel box section would be best to use? 3/4mm?
http://www.metals4u.co.uk/welding/we...sp?prd_id=3124Last edited by biketrialsdave; 06-07-2014 at 07:11 PM.
06-07-2014 #4
06-07-2014 #5
I will find all my gear and get hold of some scrap metal sometime this week! :) It's always good when you find a reason to use an untouched tool! Out of interest, how are people bolting their linear rails to box section? Bolt all the way through both sides?
06-07-2014 #6
You can't bolt all the way through as it would squash the box section without spacer tubes I used 5mm box section so just drilled and tapped it but others have glued a steel plate inside the box section with gorilla glue and then drilled and tapped. As Dean says you don't have to be super accurate because you can use epoxy on the top with a moat between the rails so that it levels out on the same plane.
When and if you come to this step just ask as quite a few people on here have used it. I used the Wests System which is ultra slow curing ie 15 -20 hours and so levels out very well ..Clive
06-07-2014 #7
Why is it not possible just to drill a bigger hole in the bottom face of the tube and nut up to the underside of the top face? G.
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
