    Speaking as a pretty second-rate welder, I found it really useful to build the bulk of the frame using just one spot of weld at each joint. I then used a series of Spanish windlasses, sash cramps, etc, to pull it all square before going round and building up the welds. Diagonal bracing followed. I cut all the box section as accurately as I could using an angle grinder in a cheap stand but it wasn't perfect. Your cutoff saw might do better. And if it goes pear-shaped (literally!) then there's always the angle grinder to cut the weld to start again - another reason not to weld too much before you're happy with the shape. The great thing about welding is that for something like this, it is very forgiving. I cut one piece on the wrong side of the line, but built back up with weld and ground back to dimension...
    Good tips! Hopefully I will get some time over the weekend to practice with my new tools :) Still got a LOT of design work to do...I'm thinking of moving away from the FF blocks + aluminium plate for the Y axis and maybe just using steel channel (or angle) welded to the box section and mounting BK blocks to it? One of my biggest concerns for the whole project is actually drilling accurate/straight holes! I have a pillar drill but it is pretty useless as there is a lot of slop in the chuck.
    This is the jig I bought, got to be worth a punt at £21!:
    http://www.ebay.co.uk/itm/1114096787...84.m1497.l2648
    Quote Originally Posted by biketrialsdave View Post
    Anyone got any opinions on the above? I appear to be coming to a point where I'm not sure where to go next. Still not happy with the X motor on the outside of the gantry plate either :(
    I wouldn't worry too much about the stepper sticking out the side of the gantry (I'd have called that the Y stepper but there's no hard and fast rules) as it's just basically a metal lump there's not a huge amount to go wrong as you have it. If you can't design it such that it's internal maybe consider sticking a bent aluminium box around it. I managed to squeeze my Y stepper inside the gantry (see here) but it's pretty tight and I expect to be replacing the belt more frequently that usual. That's not quite the final design that I've gone for but it shows the basic layout.
  1. aluminium profile for cutting bed of router
  2. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 02:01 AM
  3. Multiple CNC Opportunities both Nationally and Internationally
    By cnc jobs in forum Opportunities Available & Sought
    Last Post: 21-09-2012, 01:01 AM
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
