    I know what you're saying, that is a concern of mine. At the moment I'm using a thk kr33 assembly as I bought it a while back. However, I am planning to use the excess thk linear rail that I'll have left in the future. Perhaps I should design that in now...
    Quote Originally Posted by biketrialsdave View Post
    No perhaps about it Dave needs to be done. The Z axis is KEY area don't matter how well built rest of machine if Z is shite or weak.!!
    OK, I'll get onto that tomorrow! I assume 2 linear rails with the ballscrew in-between them sitting in a slot to reduce the overall depth? I'm using THK HSR15 carriages for the other axis, I assume these will be OK for the Z too?
    The drop brackets on the rear are 5mm steel at the moment. I can increase this and also add some kind of right angle bracket perhaps.
    Lives in Plymouth, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    Even if you don't really need them for strength, this is one place where "20" rails and carriages can be useful to give just a bit more clearance between Z plates for the ballscrew and nut. If you have to buy them and don't have something in stock already, this might be something to consider.
    Yes more than enough regards forces etc but has pointed out by neale 20mm can work better regards spacing etc. Personally I use 20mm on all axis for simplicity and hardly any difference in price.
    Yes you need more bracing to stop deflection. 5mm steel isn't really upto to it without being braced.
    I have 15mm rails on Z and they work ok but they use M3 bolts on the rail and carriages which look very small compared to M5 on the 20mm rails on my Y axis. When cutting I can feel vibration across them especially the top ones and for this type of machine I would go with 20mm on Z.
    Thanks for all the feedback guys. I think I'll go with Hiwin 20mm for the Z axis. What would be the "minimum" recommended centre distance between the two rails? I want to keep this as small as possible to maximise the effective Y axis length but without compromising rigidity. At the moment my whole Z axis assembly is 130mm wide..
    Well generally I always suggest 250mm minimum, obviously this harder to achieve on smaller machine with smaller z assembles...
    .Me
  1. aluminium profile for cutting bed of router
  2. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 02:01 AM
  3. Multiple CNC Opportunities both Nationally and Internationally
    By cnc jobs in forum Opportunities Available & Sought
    Last Post: 21-09-2012, 01:01 AM
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
