Yes more than enough regards forces etc but has pointed out by neale 20mm can work better regards spacing etc. Personally I use 20mm on all axis for simplicity and hardly any difference in price.
Yes you need more bracing to stop deflection. 5mm steel isn't really upto to it without being braced.
20-11-2015 #2
I have 15mm rails on Z and they work ok but they use M3 bolts on the rail and carriages which look very small compared to M5 on the 20mm rails on my Y axis. When cutting I can feel vibration across them especially the top ones and for this type of machine I would go with 20mm on Z.
21-11-2015 #3
Thanks for all the feedback guys. I think I'll go with Hiwin 20mm for the Z axis. What would be the "minimum" recommended centre distance between the two rails? I want to keep this as small as possible to maximise the effective Y axis length but without compromising rigidity. At the moment my whole Z axis assembly is 130mm wide..
21-11-2015 #4
21-11-2015 #5
My Z axis plate is 147mm wide and the Z rail centres are only 115mm apart. I did this to maximise Y travel and placed my Y axis bearings pretty much back-to-back.
This works fine for me, but it can give you more stability and less likely to rack if the Y bearings are spread further apart, but you are trading Y travel. If you do spread the Y axis bearings out further, closer to Lee's figure, then I don't think you need to follow suit with the Z rails and can keep them fairly compact.
22-11-2015 #6
Your machine looks great, thanks for all the advice.
I've increased the plate width to 170mm now. The z rail centres are 118mm apart at the moment. Do you think the carriages need to be separated more in the z axis? (They are 119mm centres) I'm trying to reduce this length as much as possible in order to reduce the total height of the z axis plate (if that makes sense.
Also, is it worthwhile pocketing the carriages slightly like I've done elsewhere?
22-11-2015 #7
My rear plates are between 180-200 wide which I find is good balance between strength and space saving for a small machine. On larger machine I will try to make wide has possible to get most ridgidty. Carriage separation I make wide has possible and take the bearings to the edges of plates. Vertical Separation is roughly half the rails length.
Regards the pockets then it depends on the material your using.? If your using Ground cast plate then no because it defeats the object of the plate being ground. If just rolled Plate then yes it needs to be machined because it's often not flat.
If using Ground plate and you want registers for the bearings then Mill some Aluminium blocks or dowels into the plate inline with the edge but slightly overhanging the bearing side then secure with loctite.
Then Machine away the overhanging part to give your reference edge but set cutting tool flush with ground surface so not cut away. In practice it's actually much quicker than buying rolled plate and machining away pockets and more accurate.
Personally I tell people not to bother unless they are sure the whole machine is accurate from base upwards because they make adjustment much harder and in flexible.
In an idle world then yes you'd have them but the reality is that building in your Man cave then in-accurecy is sure fire going to be there so any thing to help adjust error out is welcome.
Also in DIY setting then it's unlikely you'll be chasing Um accurecy and neither will you be stripping it down every other week. So provided you take care when setting up and use good quality fasteners, tighten them up properly and use retainer then you'll not have any troubles and chasing away error will be so much easier.
One potential Gotcha I spotted on your drawing. The holes in the Top and bottom plate which fasten them to the rear plate may interfear with the bolts on the Gantry bearings.? Easy done so check it.!Last edited by JAZZCNC; 22-11-2015 at 02:17 PM.
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
