27-11-2015 #11
#1 Drill the Plate and screw from under side.
#2 Drill thru the upper extrusion and bolt into lower T-slots. Can add some Blocks into the slots to stop them sliding.
#3 If just bracing then 5mm steel will be just about ok, But personally I'd use 9.5(3/8")mm Aluminium so don't have hassle of painting etc plus steel on ali is not good mix.
#4 Can do it but it's difficult and not very effective unless high vacuum. Much better with Blown air and minimal Mist to clear/Lube chips.
#5 Simple holes at one end and angle the machine on bench using feet.
There are currently 15 users browsing this thread. (0 members and 15 guests)
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
