Have you thought about just using one belt and one motor and drive, I use two motors but quite a few on here use one as it is easier to home and stops the problem of racking etc. Just a thought!
30-12-2015 #3
There are pro's and con's for the two systems I don't think there is much difference in cost between the two.
With two motors you will need two homing switches and a controller that can do the slaving correctly and also have the alarm outputs on the drives working in case one motor stalls and then the other will rack the system.
Dean (Jazzcnc) usually uses one motor but I think on the machine he is now using it has two.
I use two motors and I am happy with it...Clive
30-12-2015 #5
Yes it has but only because I inerited the machine it probably wouldn't if I built it my self.! . . . Thou It's just on the edge of too big for belts so maybe not.?
On large machines 2 motors make more sense because the belts get messy and custom lengths. At this size and with this design then I'd 100% be using belts.
It's only slightly cheaper in cost but much more reliable and stable in use. Can make full use of the machines potential and not worry about screws running out of sync with each other.
If using 2 motors then the ONLY way I'll use them is if the drives have Stall detect with fault output to E-stop the machine ie: EM806 or AM882 . Also external motion control card is prefered due to higher work load. (Personaly I won't use the Parallel port on any machine)
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
By ciscoeuk in forum DIY Router Build LogsReplies: 19Last Post: 03-02-2013, 02:01 AM -
Multiple CNC Opportunities both Nationally and Internationally
By cnc jobs in forum Opportunities Available & SoughtReplies: 0Last Post: 21-09-2012, 01:01 AM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM
