Page 3 of 5 FirstFirst 12345 LastLast
  1. #21
    0.01mm is about the resolution of my stepping setup. Mechanically a C7 screw and nut is 0.05mm or better.
    I think these sensors are a good match for my system. Anything more would have been overkill but I can see why you'd like better if your doing the kind of precision work that absolutely requires it to be dead on.
  2. #22
    The other issue you can get with these that you don't get with a 3D printer is keeping then clear of swarf? you would need to shield them very well
  3. #23
    Given that they're NC when not activated, if you want to connect them through a single pin, then you'll need some way to invert the signal.
    Missed this but it's easy fixed just set the Home input to Active low and it will see the signal when it goes low IE: The switch opens.
  4. #24
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,989. Received thanks 373 times, giving thanks to others 9 times.
    Still wouldn't work for homing ;-)
    Wiring three to the same pin, unless you can make sure 2 are triggered (i.e switched open circuit) while you home the third one, it's not going to work.
  5. #25
    See what you mean and didn't give it a lot of thought plus I've Never used these type Switches so won't argue but I've just been looking thru PMDX126 manual and they use them wired in parallel on a single Pin so wouldn't be so sure.?
  6. #26
    That's because the sensors in that diagram have a NO output.
  7. #27
    Ah I didn't realise these where NC switches. . . Makes sense now.!! . . . Really should start reading the threads more often.!
    (To be honest didn't even knew Proximity switches add NC - NO option never used them or thought about it. Thought they just sensed magnetic fields but on reflection it's obvious it's just an electrical circuit so could have and would need to both options to work has switches. . . Doh.!!)
  8. #28
    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    I thought I'd bounce this thread as I have a question related to the ALM output from a Leadshine drive (EM806, which is pretty much an upgraded AM882).
    Is it safe to wire the ALM straight to a PIC pin, or should I use another (opto) transistor in the middle somewhere to isolate the two?
    Regards,
    T.
  9. #29
    Quote Originally Posted by dsc View Post
    Regards,
    T.
    I'm no electronics expert but think it should be ok has the alarm output can sink or source 20ma @ 24V and don't think the Pic will kick out more than 5V.
    Something I do know thou is don't want you to blow my bloody drive up So be sure before trying. .Lol
  10. #30
    dsc's Avatar
    Lol, I'm not keen on blowing anything up, thus the question :D
    Regards,
    T.
  1. Leadshine website and AM882
    Last Post: 24-08-2018, 01:59 AM
  2. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  3. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  4. Output direct to machine
    By picyman in forum Vectric
    Last Post: 16-02-2014, 11:04 PM
  5. HPGL driver output
    By 2006Nobull in forum Computer Software
    Last Post: 07-10-2012, 08:49 PM
