Hey guys,
I know this thread is a little old but it's about he only decent thing that comes up when I searched "AM882 alarm wiring". I just registered to post this update.
This is just an FYI how mine worked. I have 2 motors on one axis and I didn't want the driver to sense something that would put it in to alarm and stop one motor while the other kept going. Hope that makes sense. I wanted that if one driver went into alarm that the others would stop.
Turned out really simple. In the software set the alarm to go "LOW". Run the E-Stop though as many switches as you need then end at the "ALM +" of the first drive then "ALM -" to the "ALM +" of the next and so on. After the last drive "ALM -" goes back to the control board "GND" and that's it. Job done. If any drive goes into alarm, the circuit is broken and E-Stop is activated.
Happy Days
The Following User Says Thank You to joel0407 For This Useful Post:
31-07-2017 #2
Hi Joe and welcome to the forum. There are a lot of people on here that use the AM882 drives and the later model EM806 both are very good drives and for a gantry machine a must, because like you have pointed out the alarm feature
31-07-2017 #3
I just thought the beginning of the thread got a bit complicated with using relays and the such. I don't know if the op had used a different control board or something and it had me a little confused. I know how to use a transistor and a relay but couldn't work out the alarm port on the AM882.
I expected it to be simple open circuit and closed circuit when alarming or not. What threw me off the most was putting a multi-meter across the terminals didn't show continuity or only a few millivolts on DC. I figured there wasn't enough voltage to do any damage so I just give it a go running a jumper from the E-Stop on my Parallel Breakout board, "ALM +" then "ALM -" back to the GND on my break out board. What do you know it worked then I found it also worked jumping them all together so all good..
Happy Days
Joel
31-07-2017 #4
31-07-2017 #5
There are drawings here; http://www.mycncuk.com/threads/6565-...2213#post52213
of how I wired them.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
31-07-2017 #6
One thing to be aware of with doing this, is the alarm outputs may have a slight voltage drop (I've just checked the EM manual and it doesn't give any specs, but electronic open collector type outputs typically have a voltage drop, unlike true mechanical relay contacts). So if you connect multiple drives in series, you risk increased interference/noise issues.
I.e. if you're connecting to a TTL level type input, which needs a guaranteed voltage below 0.7V to be active, if you connect 4 drives with a 0.1V drop, you then only have a noise margin of 0.3V.
Off course, the exact effect will vary depending on the kind of input you're using. If you were to get noise problems, the simplest solution would be to add a relay controlled by the alarm/e-stop circuit, as a reasonable amount of current is needed to activate the relay, which should be far greater than anything noise/interference would cause.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
01-08-2017 #7
Leadshine website and AM882
By EddyCurrent in forum General ElectronicsReplies: 12Last Post: 24-08-2018, 01:59 AM -
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM -
Output direct to machine
By picyman in forum VectricReplies: 4Last Post: 16-02-2014, 11:04 PM -
HPGL driver output
By 2006Nobull in forum Computer SoftwareReplies: 6Last Post: 07-10-2012, 08:49 PM
