Thread: Spindle Stop?
Page 2 of 2 FirstFirst 12
    Or perhaps you could use a switched fused spur to feed a double sockect
  2. The Following User Says Thank You to Clive S For This Useful Post:
  3. #2
    Ray I wouldn't put the Mill spindle and the Control box on the same fuse.? If the spindle bogs down and just happens to draw a bit more power when the steppers are working hard then the combination of control box and spindle could trip the fuse. Where's on there own fuse's the Mill spindle will handle the Bog and continue without affecting the control box.
    If you want true safety use a relay system to shut the other down. This way both protect each other in case of failure or power loss and the relay in control box will stop the spindle if it goes offline and vise versa the spindle relay will inform the Control box it's failed which will then stop things in a controlled manner turning off or killing power to other important attachments and halting Mach3.
    You can also control the spindle ON/OFF thru Mach3 and G-code in a similar way.
  5. #3
    Hi, many thanks for all the advise, it's now getting heavy (I am a retired Mechanical engineer) but i do not give up easily, forgive me a few more questions.
    Hi Jazz, what is a Bog ?
    Would a drawing of a relay schematic be possible from anyone, as I read drawings ok, sometime the written / verbal passes me by.
    Regards
    Ray
  6. #4
    Quote Originally Posted by manofgresley View Post
    Ah ah probably a Yorkshire saying.!! . . By this I mean if Spindle comes under heavy load from sticky material or hard spots and starts "Bogging down" on speed and increasing the Amp load on fuse.
  8. #5
    I know this is a simple take on things but here is a circuit that does the job..
    If anyone has a better circuit post it up so we can help this chap out LOL
    Rick
  9. The Following User Says Thank You to Ricardoco For This Useful Post:
  10. #6
    Hi Rick, are the latching switches just for lamp indication, if yes can i get rid of them, don't want to make it to complicated yet.
    Regards
    Ray
  11. #7
    Regards
    Ray
    the switches do have lamps in them but they are not required, the switches are there to latch the relay on so when power is lost to either relay it unlatches and stops the other supply, like an interlock circuit one is dependant on the other.
    The switches i have used are on off two button switches one NO and one NC, the NO switch gives power activating the relay and hence giving power through its contacts to itself and the NC switch is used to break the circuit de-energising the relay.
    You could of course use two seperate switches per relay one momentry NOand one momentry NC. Im just lazy and opted for the one with a light in it... (i like lights!!.. before someone else chimes in)..
    Rick
    if your on a tight budget let me know and ill post over a couple of switches without lights FOC..
  12. #8
    Hi Rick.
    That's very generous of you, yes i am on a can spend when i have got the money budget (She who must be obeyed) i am retired now so everything helps, so i will accept your offer, do you have e mail and i will send my address.
    Regards
    Ray
  13. #9
    Hi Rick.
    Regards
    Ray
    Ok Ray ive senty you a PM, Im away at work till friday so Ill pack them up and see if i can post then.
    Regards Rick
  14. The Following User Says Thank You to Ricardoco For This Useful Post:
  1. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  2. I promise I will stop asking daft question soon. Ish.
    Last Post: 15-10-2012, 11:37 PM
  3. wiring e-stop button
    By deannos in forum General Electronics
    Last Post: 14-01-2012, 11:03 AM
  4. End mill depth 'stop' rings
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 02:03 AM
  5. Wiring in power and E-stop on DIYCNC Board
    By m.marino in forum General Electronics
    Last Post: 10-05-2009, 10:15 AM
