Thread: Spindle Stop?
    Quote Originally Posted by manofgresley View Post
    Hi Guys
    Thanks for your contribution so far, but i think there is still some misunderstanding, to answer a previous question, my Mill is powered from a Standard 13 amp 3 pin outlet. I have enclosed my BLOCK diagram of what is actually the condition of my system now, I have 3 different 3 pin 240 vac supplies, all with there own 10 amp fuse, if Mill blows fuse due to overload condition, cabinet and PC are still Powered.
    Regards
    Ray
    Ok then change it to this, Job Done.. if you can that is..
    Rick
  2. The Following User Says Thank You to Ricardoco For This Useful Post:
  3. #2
    Hi Rick
    That looks great many thanks, IYHO what would be the best way to divide the 240 supply, my thoughts are a 240 volt busbar in the cabinet, with a tap off to the Mill and a tap off to the rest of the cabinet.
    Regards
    Ray
    Hi Rick
    Regards
    Ray
    As jazz has pointed out using a relay (with the correct rating)is really the best way, but if not then have their own fuses. But the first is preferred as there is a higher degree of control when using a relay. Rick
  5. The Following User Says Thank You to Ricardoco For This Useful Post:
  1. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  2. I promise I will stop asking daft question soon. Ish.
    Last Post: 15-10-2012, 11:37 PM
  3. wiring e-stop button
    By deannos in forum General Electronics
    Last Post: 14-01-2012, 11:03 AM
  4. End mill depth 'stop' rings
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 02:03 AM
  5. Wiring in power and E-stop on DIYCNC Board
    By m.marino in forum General Electronics
    Last Post: 10-05-2009, 10:15 AM
