Thread: Spindle Stop?
    I know this is a simple take on things but here is a circuit that does the job..
    If anyone has a better circuit post it up so we can help this chap out LOL
    Rick
  2. The Following User Says Thank You to Ricardoco For This Useful Post:
  3. #2
    Hi Rick, are the latching switches just for lamp indication, if yes can i get rid of them, don't want to make it to complicated yet.
    Regards
    Ray
    Quote Originally Posted by manofgresley View Post
    Regards
    Ray
    the switches do have lamps in them but they are not required, the switches are there to latch the relay on so when power is lost to either relay it unlatches and stops the other supply, like an interlock circuit one is dependant on the other.
    The switches i have used are on off two button switches one NO and one NC, the NO switch gives power activating the relay and hence giving power through its contacts to itself and the NC switch is used to break the circuit de-energising the relay.
    You could of course use two seperate switches per relay one momentry NOand one momentry NC. Im just lazy and opted for the one with a light in it... (i like lights!!.. before someone else chimes in)..
    Rick
    if your on a tight budget let me know and ill post over a couple of switches without lights FOC..
  5. #4
    Hi Rick.
    That's very generous of you, yes i am on a can spend when i have got the money budget (She who must be obeyed) i am retired now so everything helps, so i will accept your offer, do you have e mail and i will send my address.
    Regards
    Ray
  6. #5
    Hi Rick.
    Regards
    Ray
    Ok Ray ive senty you a PM, Im away at work till friday so Ill pack them up and see if i can post then.
    Regards Rick
  7. The Following User Says Thank You to Ricardoco For This Useful Post:
  1. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  2. I promise I will stop asking daft question soon. Ish.
    Last Post: 15-10-2012, 11:37 PM
  3. wiring e-stop button
    By deannos in forum General Electronics
    Last Post: 14-01-2012, 11:03 AM
  4. End mill depth 'stop' rings
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 02:03 AM
  5. Wiring in power and E-stop on DIYCNC Board
    By m.marino in forum General Electronics
    Last Post: 10-05-2009, 10:15 AM
