    Hi all,
    I'm a bit confused as to what the minimum requirements are on a break out board. My planned system is a PC with LinuxCNC, BOB, drivers and stepper motors.
    Take this for instance:
    Obviously there are no opto couplers to protect the computer. But is anything else needed for comunicating with the stepper drivers?
    Patrik
    I've upped my standards. Now, up yours!
    From my experience a breakout board is simply a extension of the connecting port which makes it easier to connect the wires. I would have thought opto couplers would be a high priority though.
  3. The Following User Says Thank You to IanS1 For This Useful Post:
    Try doing a search on the forum, someone asked a question like this not that long ago & there were some good explanations given.
  5. The Following User Says Thank You to martin54 For This Useful Post:
  6. #4
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    This is the one that I have bought CNC4PC as the one that was supplied for free with the drivers I found would not work well with the pp. This one worked staight out of the box and is independant and isolated from the pp.
  7. The Following User Says Thank You to Clive S For This Useful Post:
  1. MACH 3 requirements
    By manofgresley in forum Artsoft Mach (3 & 4)
    Last Post: 08-01-2020, 07:22 PM
  2. Replies: 0
    Last Post: 13-02-2014, 07:09 PM
  3. Break board 3-axis optical isolation, simple!
    By thjremy in forum Electronic Project Building
    Last Post: 06-04-2013, 04:42 PM
  4. optoport v3 break out board wiring
    By lez allen in forum Motor Drivers & Controllers
    Last Post: 26-02-2013, 07:38 PM
  5. Motor controller next to break out board?
    By m_c in forum General Electronics
    Last Post: 17-11-2010, 01:56 PM
