Thread: dc motor - spindle / shaft drive
Thanks for the info Mark, the startup torque will be an issue though as the machine will be packed with coffee and that is when the high torque is needed, to get things moving. Once the thing starts spinning, the torque requirements drop to low levels.
Jazz, the 9Nm was measured with a torque wrench, hand cranking manually and changing the settings on the torque wrench (going up from 5Nm, 1Nm at a time, each time it clicked). I was surprised as well, but as I said above, that's static torque, dynamic is much lower.
Regards,
dsc.
09-01-2013 #2owch! that is a pain :(I was surprised as well, but as I said above, that's static torque, dynamic is much lower.
I cant find any torque info on the DC motor either but im getting the feeling it would struggle in this application without a big ratio
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
advise on drive shaft diameters
By bmbaz in forum Machine DiscussionReplies: 2Last Post: 15-05-2014, 10:46 AM -
pulley fit on motor shaft - force it on?
By dsc in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 09-08-2013, 06:11 AM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM
