Thread: What stepper motor size (torque)
04-02-2009 #4
Steppers are constant power devices Power = revs * torque, i.e. as revs increase, torque drops off. Max torque is at or near stall. However as revs (= step rate) increase this linear relationship breaks down because of what you refer to Lee, which is the L/R constant of the motor. The rate of rise of current in the coil is proportional to the inductance: Since torque is directly proportional to current, for larger inductances you need to drive the coil harder (e.g. higher voltage) to reduce this torque drop off at higher step rates.
The formula is V = 32 * sqrt(L) where L is in mH. A 10mH coil ideally therefore needs a drive of 100v, but of course most steppers have a winding breakdown of 65 - 80v and 100v drivers are expensive anyway. What it means is that such a motor on a 48v driver (e.g. a Gecko) will not maintain torque above about 60% of max step rate. A better motor for a 48v drive would have an inductance no more than 2.25mH.
But too large a motor can be as much a problem as too small. Big motors have more rotor inertia which can reduce the ability to accelerate (e.g. change direction when cutting). You need to choose a motor thats in the 'sweet spot' else you can end up with nasty resonance issues (as well as pay more than you need to for both motors and drivers). The 'sweet spot' is an operating torque at cutting speed about 40% margin over what's needed. Thats NOT the same as stall torque which is how motors are rated. Its also important to ensure that the step rate at cutting speed is below that at the knee point (where the L/R effect starts). That may mean the steppers need to be geared to the leadscrews which also changes the inertial and torque dynamics. Hence the need to do the calculations.
What size stepper motor do I-need.
By irving2008 in forum Stepper & Servo MotorsReplies: 46Last Post: 15-06-2017, 09:18 AM -
motor mount vibration vs torque'd bolts
By dsc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 22-10-2013, 10:36 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
High Torque Motor Z Axis
By Lee Roberts in forum Stepper & Servo MotorsReplies: 5Last Post: 17-05-2009, 10:08 PM
