12-01-2013 #11
I wonder if this is where strikecnc got the idea of not using proper bearings on the ballscrews.
Anyway, I think the easiest way to solve this is to buy a pair of FK/FF bearing blocks since so long as the extrusion is long enough you can drill a hole in either side and put the new bearing mounts in. That's assuming the ballscrew end machining is standard, what does it look like?
Also, I'd solder those motor connections as if they work loose whilst the machine is running the stepper driver could be damaged.
FOR SALE: Marchant dice cnc router mill compatiable with mach 3
By gavztheouch in forum Items For SaleReplies: 7Last Post: 23-03-2021, 12:59 PM -
BUILD LOG: A3 Marchant Dice Kit
By neo in forum DIY Router Build LogsReplies: 25Last Post: 03-03-2021, 11:54 AM -
Marchant Dice
By agent17 in forum Marketplace DiscussionReplies: 28Last Post: 06-06-2020, 11:06 AM -
Marchant Dice on eBay
By irving2008 in forum Marketplace DiscussionReplies: 4Last Post: 06-09-2008, 05:37 PM
