    Quote Originally Posted by Walterronny View Post
    Motor mounts (idk how they go mounted with the motors!)
    Walter,
    For your review, here is a very good way of designing/making motor mounts, they incorporate angular contact bearings so may save you some time at design and money on additional parts.
    Pictured is the face the motor will attach to, on the other side there is just a simple bore to recive the anguler contact bearings, on the second picture you can see an option for supporting your leadscrew (at the other end) with just normal radial bearings.
    Good luck with the build !
    .Me
ID:	8148   Click image for larger version.
    Just had some times to draw motors, havent...more sizes so i got this according drawing from here Nema23 Stepper Motor 3.1Nm x 3
    3 motors i will need :)
    I will make motor mounts and post here
    if you have drew them you have far too much time on your hands :P good luck with the build sorry i cant help with anything i'm still too new
    hahaha well, both draws didnt take much time to do.
    Thanks anyway! :)
    Base, using 50X100 square steel , 800mm and 600mm for using 790 X 590 linear rails
    What do you think about sizes?
    Made rails and blocks.. this week i will make more parts. any input, feel free to comment!! :)
    splendid, this is where drawings start to earn their keep...
    if you are hoping to use nuts on those rails it may pay to have the long box sections open instead of the short ones like you have drawn
    it will still be a pain to get nuts in but not impossible :)
    run the rails all the way to the back of your frame in light of the fact that your Z axis is likely to have an overhang that will push your cutting aria forward too the inside of the aperture of your frame
    you may need to extend the frame to keep the Z inside the frame at its furthest reach… easy enough to amend as the drawing develops :)
    yes, holes go to the other side, it's not possible to see in the draws :)
    About to run the lighs to back, ok, noted it1
    Really the area i need is 600X400mm, in think i will go a bit oversize since i designid it with 800X600 and 790X590 rails..
    Thanks for your help Blackburn!
    Quote Originally Posted by Kerryfisher View Post
    Great info!! i think i will use that way!
    Treemonkey, i use solidworks w/ keyshot.
  1. RFQ: Plasma job...
    By Boscoe in forum Projects, Jobs & Requests
    Last Post: 17-09-2013, 08:43 PM
  2. what electrics cnc kit to use for 3x4 cnc plasma
    By whensparksfly in forum Plasma Table Machines
    Last Post: 27-02-2012, 07:33 PM
  3. First Plasma Cutter
    By antsals in forum Plasma Table Machines
    Last Post: 16-05-2011, 07:58 AM
  4. my first plasma build
    By oadamo in forum DIY Plasma Build Logs
    Last Post: 31-12-2010, 07:15 PM
  5. plasma cad
    By jamied in forum Computer Software
    Last Post: 20-08-2010, 03:33 PM
