Thread: My first CNC plasma
12-01-2013 #1normally we would have our bearing blocks further apart than this however I’m assuming Chai understands that this is for a plasma cutter and has calculated that having the two bearing blocks tight up against each other will work fine in this applicationThey told me i would need 690X490mm rails, i assume that will be ok, do they?
personally i would be more comfortable with 50mm to 100mm gap between the blocks especially on your X axis (making the rails 790x590)
But I think I may be being over cautious
Your drawings don’t have to be perfect :)
it is a good idea to show some drawings before you commit to buying equipment as it is quite to easy to overlook something simple
good luck :)
13-01-2013 #2
RFQ: Plasma job...
By Boscoe in forum Projects, Jobs & RequestsReplies: 3Last Post: 17-09-2013, 08:43 PM -
what electrics cnc kit to use for 3x4 cnc plasma
By whensparksfly in forum Plasma Table MachinesReplies: 0Last Post: 27-02-2012, 07:33 PM -
First Plasma Cutter
By antsals in forum Plasma Table MachinesReplies: 3Last Post: 16-05-2011, 07:58 AM -
my first plasma build
By oadamo in forum DIY Plasma Build LogsReplies: 11Last Post: 31-12-2010, 07:15 PM -
plasma cad
By jamied in forum Computer SoftwareReplies: 6Last Post: 20-08-2010, 03:33 PM
