Thread: My first CNC plasma
12-01-2013 #1
Hi guys, im introducing to this world, i have not much idea about how it works really but im trying to reading a lot. I decided to post a new build threard here . ( thread of my introdution http://www.mycncuk.com/forums/new-me...-new-here.html)
Machine i want to build is for exhaust flanges and so, not bigger parts really , maximum size should be 600X400mm, thanks to blackburn for info i will order soon linear rails to them:
linear rail SBR16-1200mm(4 rails+ 8 SBR16UU blocks),SUR | eBay
They told me i would need 690X490mm rails, i assume that will be ok, do they?
Drivers for controll the motors (i assume) will be this:
CNC Wantai Digital Control 4Axis Stepper Driver,24-80VDC/7.8A www.wantmotor.com | eBay
And the motors i will get this :
http://www.diycnc.co.uk/html/cnc_systems.html
I can't design it yet with solidworks since i have not idea about sizes and what other parts i would need really, if any has any input i will appreciate it a lot. Thanks.
Walter .
12-01-2013 #2
Hi there Walter, I take it you have got a plasma to start with.. For the height control you can do it manually or just get one of these units to put on to your plasma..
Proffessional Compact CNC Plasma THC Controller ( Torch Height Control ) | eBay
They are very good and save a lot of headaches if you choose to cut thinner metal it can warp and cause you problems.. this unit takes away all the pain.. there are some pictures and instructions of the setup at the bottom of the page, ive fitted a couple of these and was very impressed..
I am building a plasma/router myself at the moment. I will keep an eye on your thread and if i can help in any way let me know, ive been using the plasma at least once a month lately as im building an american hotrod (40/32 ford with hemi motor) as a side project, so you can see my need for a cnc as well for fabrication
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
12-01-2013 #3
Hi, woow!! great info!
i havent plasma yet, i really havent any parts, just reserarching info but next month i will begin to buy some parts like linear rails and motors..
what plasma machine do you use? what is the maximun thickness machine cuts?
Any info , pictures about router will be appreciate it alot.
Thanks Rick!
12-01-2013 #4normally we would have our bearing blocks further apart than this however I’m assuming Chai understands that this is for a plasma cutter and has calculated that having the two bearing blocks tight up against each other will work fine in this applicationThey told me i would need 690X490mm rails, i assume that will be ok, do they?
personally i would be more comfortable with 50mm to 100mm gap between the blocks especially on your X axis (making the rails 790x590)
But I think I may be being over cautious
Your drawings don’t have to be perfect :)
it is a good idea to show some drawings before you commit to buying equipment as it is quite to easy to overlook something simple
good luck :)
12-01-2013 #5
I have a Cut 50 and it will cut 10mm at a push but it is rated at 8mm. and cuts that easy. Do you have a compressor for the plasma yet? Remember Dont just buy the first hardware that you get told about have a look around and see if you can get a deal or bargain, the further you can get your cash to go the better later on.. Plan it, post it, re-plan it, re-post it, and so on..
12-01-2013 #6
The same motors are cheaper here:
Nema23 3.1Nm
13-01-2013 #7
13-01-2013 #8
13-01-2013 #9
13-01-2013 #10
Just had some times to draw motors, havent...more sizes so i got this according drawing from here Nema23 Stepper Motor 3.1Nm x 3
3 motors i will need :)
I will make motor mounts and post here
RFQ: Plasma job...
By Boscoe in forum Projects, Jobs & RequestsReplies: 3Last Post: 17-09-2013, 08:43 PM -
what electrics cnc kit to use for 3x4 cnc plasma
By whensparksfly in forum Plasma Table MachinesReplies: 0Last Post: 27-02-2012, 07:33 PM -
First Plasma Cutter
By antsals in forum Plasma Table MachinesReplies: 3Last Post: 16-05-2011, 07:58 AM -
my first plasma build
By oadamo in forum DIY Plasma Build LogsReplies: 11Last Post: 31-12-2010, 07:15 PM -
plasma cad
By jamied in forum Computer SoftwareReplies: 6Last Post: 20-08-2010, 03:33 PM
