Thread: My first CNC plasma
Hi Robin, appreciate a lot your suggestions, this is my first plasma im build so i have not much idea about it, i was thinking in to make it light too but when i was designing it that's what i got lol! i was thinking in to make a solid support but not too heavey, if you have any suggestion of how do i can improve the actual design i will appreciate it a lot.
About welded iron you means the "yellow" parts? or what exactly do you means?
Thanks again!
15-01-2013 #2
Apologies for that, I have a touch of insomnia, really should not do forums at 3am. If you are using aluminium and gusset plates, nil problemo, it is adjustable.
There's lots of good info on plasma over on cnczone but the Americans do seem to follow a formula which may or may not be optimum. If you don't use a Hypertherm they look on it as a cure for all your ills.
I'm currently tryng to make a lightweight plasma Z axis by 3D printing. The American method to get pierce and cut heights is by sensor and stepper motor, but that leaves you with a stepper interface to do THC which is an analogue thing I suspect may be better handled by a DC motor. I could be completely wrong, won't know until I try it.
RFQ: Plasma job...
By Boscoe in forum Projects, Jobs & RequestsReplies: 3Last Post: 17-09-2013, 08:43 PM -
what electrics cnc kit to use for 3x4 cnc plasma
By whensparksfly in forum Plasma Table MachinesReplies: 0Last Post: 27-02-2012, 07:33 PM -
First Plasma Cutter
By antsals in forum Plasma Table MachinesReplies: 3Last Post: 16-05-2011, 07:58 AM -
my first plasma build
By oadamo in forum DIY Plasma Build LogsReplies: 11Last Post: 31-12-2010, 07:15 PM -
plasma cad
By jamied in forum Computer SoftwareReplies: 6Last Post: 20-08-2010, 03:33 PM
