27-01-2013 #6
Thanks for the reply's so far. Panels are a good idea. As for beefing up the frame, I thought I'd already done that ??.
I am going to add more corner plates between the profiles and add a aluminium plate behind the Y rails, but apart from that I don't see what else would beef it up apart from welding the profiles together !Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
BUILD LOG: I've built this machine 100 different times in my head!!!
By Iwant1 in forum DIY Router Build LogsReplies: 72Last Post: 13-06-2017, 08:18 PM -
machine cutting sequence, keeps returning to the original point
By luke11cnc in forum Machine DiscussionReplies: 3Last Post: 06-07-2013, 04:48 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Setting a start point.
By jrob3rts in forum Computer SoftwareReplies: 14Last Post: 17-06-2012, 12:36 PM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
