08-03-2014 #10
Yep, probably is...but I for one could not have marked or drilled the holes accurately enough without the CNC I already have. My pillar drill drills egg shaped holes, so I do all my counter-boring and through holes on my machine.
Kind of like people with 3D printers, they make parts for more 3D printers !
The machine I have gives very good results but lacks in perfect smooth edges. So hence the new axis.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
BUILD LOG: I've built this machine 100 different times in my head!!!
By Iwant1 in forum DIY Router Build LogsReplies: 72Last Post: 13-06-2017, 08:18 PM -
machine cutting sequence, keeps returning to the original point
By luke11cnc in forum Machine DiscussionReplies: 3Last Post: 06-07-2013, 04:48 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Setting a start point.
By jrob3rts in forum Computer SoftwareReplies: 14Last Post: 17-06-2012, 12:36 PM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
