Thread: Machineable foam
Hey guys,
As a hobby I build and race model cars, However as my collection over time has grown so has my battery collection(mostly lithium polymer) I want to purchase a metal case and use foam inside to protect my batteries, I would really like to machine the foam out to fit each battery to keep them separate inside.
Does anyone know of any foam that is easily machinable but also soft enough for protection?
Craig
18-01-2013 #2
If it's just for batteries then it wouldn't need to be to soft. Really just to keep them from clattering about in the case so pretty much any sort of foam would do. Generally the denser the foam the more expensive it is. You would get good results with a soft foam & a craft knife with a bit of care. That's probably how I would do it.
03-02-2013 #3
You want to use a polyethalene grade of foam, plastazote have a few different grades (Used for tool trays/shadow boards). If you struggle to find any let me know, I have a few bits kicking around.
03-02-2013 #4
03-02-2013 #5
[QUOTE=JAZZCNC;41973]Yipee your first post.!! . . . Welcome Si .
Thnx Jazz, still recovering from finding out who the man behind the mask is !!!!!
03-02-2013 #6
03-02-2013 #7
03-02-2013 #8
I've never got good results using a craft knife to cut foam, however, a wet bread knife is brilliant!
Hot Foam cutter for RC aircraft
By rckeith in forum Hotwire Cutting MachinesReplies: 25Last Post: 10-08-2015, 08:32 AM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
Machining Insulation foam
By Philly in forum Machine DiscussionReplies: 3Last Post: 28-01-2013, 12:38 AM -
Foam , crumb collection?
By Musht in forum Machine DiscussionReplies: 0Last Post: 14-05-2012, 12:19 PM -
CNC Hot Wire Foam Cutters
By HotwireCutter in forum Manufacturer NewsReplies: 0Last Post: 02-05-2012, 09:04 PM
