    I once looked deeply into making loudspeaker cabinets (big ones) and it was deemed a good idea to use a glued sandwich of MDF and plywood to reduce cabinet resonance.
    Laminating sheets is always a good thing, it does remove alot of resonanse and vibrations all together... I had hopes to find another 40mm bottom sheet this time, but sadly I did not find one for cheap this time around.
    But the overall look of the machine and the precision is more than ok for my uses. Which mainly will be woods and plastics, and perhaps a bit of aluminum.
  1. New member looking for advice on a good quality machine (brand)
    By steve78 in forum Marketplace Discussion
    Last Post: 16-08-2014, 09:25 PM
  2. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  3. NEW MEMBER: Brand new newbie
    By Grit monkey in forum New Member Introductions
    Last Post: 09-10-2013, 10:09 PM
  4. Stepper shaft size and pulley bore size problem
