  1. #28
    There's very little vibration in it. Especially after I added the 41mm MDF top to it. 22+19mm MDF.
    Plus I added extra stiffness on the crossmembers with 60x60x4mm steel tube.
    I have done a cut test in Aluminum, with a rather agressive cutting parameter, and it came out lke this, with a single flute cutter. You need to look at the area within the red rectangle.
    The cut was done rather agressively, and with a 3mm single flute cutter at high RPM. Will go for a slower RPM next time I try it. It looks bad looking at the picture, but the cut is actually very flat and smooth.
Name:	2014-09-06 21.15.58.jpg
  1. New member looking for advice on a good quality machine (brand)
    By steve78 in forum Marketplace Discussion
    Last Post: 16-08-2014, 09:25 PM
  2. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  3. NEW MEMBER: Brand new newbie
    By Grit monkey in forum New Member Introductions
    Last Post: 09-10-2013, 10:09 PM
  4. Stepper shaft size and pulley bore size problem
