  1. #35
    Well, the machine is up and running as it should be. And I have already cut a few bits and pieces in Aluminum on it. Recently I cut 16 plates in 5mm aluminum sheet.. Ended up looking really good... They are 121x156mm and tolerances are within 1-2/10 of a millimeter. Not the best tolerances, but I only had a single flute 3.175mm cutter, so it came out as it came out.. But the finish was great...
Name:	2014-12-10 15.06.42.jpg
ID:	14091   Click image for larger version.
Name:	2014-12-10 15.07.29.jpg
  1. New member looking for advice on a good quality machine (brand)
    By steve78 in forum Marketplace Discussion
    Last Post: 16-08-2014, 09:25 PM
  2. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  3. NEW MEMBER: Brand new newbie
    By Grit monkey in forum New Member Introductions
    Last Post: 09-10-2013, 10:09 PM
  4. Stepper shaft size and pulley bore size problem
