Thread: Build Log: 3-4 Axis Mill/Router
21-01-2013 #5
Yes, 25mm profiled rail. I'll look at 20mm instead. When you say twin screws, do you mean one either side? If yes, that is my intention, driven by a single motor using pulleys and belts.
Yes, the gantry need some serious beefing up and is in no way finished in the drawing. I'll do some more work on it and post again.
With regards to the resonance, I know some folks have used kiln dried sand to fill the box section but has anyone used sound deading materials stuck to the back of the skinning to help with resonance control? I have some sheets of a bitumen based damping mats which work very well for killing resonance. More info here: Bitumen Based Damping Mats [01] - £0.00 : SoundProofing Services, Sound Insulation, Acoustic Insulation, Acoustic Foam, Acoustic Panels
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
New CNC mill build
By AVRnj in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 13-04-2013, 12:19 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
NEW MEMBER: I am going to build a 3 axis servo control
By markey1979 in forum New Member IntroductionsReplies: 8Last Post: 16-11-2011, 12:53 AM
