Thread: Build Log: 3-4 Axis Mill/Router
Can I ask why you went with ecocast?
I don't think ecocast is structurally any stronger than 6082, (Jazz can probably confirmor refute this) it is just precision ground which is useful for mounting rails on but not required for the gantry sides. With the dimensions you provided, 6082 from aluminium warehouse would cost £90 +vat each as opposed to £125 +vat each for ecocast.
Edit to add, don't worry too much about the weight of the gantry, there is a really good spreadsheet here that allows you to play with figures and a few extra kgs has very little effect.
http://www.mycncuk.com/forums/faqs-p...do-i-need.html
21-01-2013 #2
Yes and no really it's not structurally stronger but it is more stable has it's cast not rolled, and yes it's precision ground. That said your still correct it's a waste for things like gantry sides etc where ground plate isn't required.!!. . . . Use it for bearing plates and Z axis mostly the rest will be fine with normal plate.
21-01-2013 #3
No particular reason for the Ecocast, 6082 it is. Thanks for the motor sizing link D.C., be useful that.
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
New CNC mill build
By AVRnj in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 13-04-2013, 12:19 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
NEW MEMBER: I am going to build a 3 axis servo control
By markey1979 in forum New Member IntroductionsReplies: 8Last Post: 16-11-2011, 12:53 AM
