Thread: Any arduino coders here?
I'll try and get some pics over the weekend.
Going by what I found stripping the X-axis, I'd say mine did originally have steppers, and the servos were part of the Heindenhain retrofit, which was done by a company I can't currently remember the name of. Underneath the covers, lots of bits havn't been painted, whereas all the original bits are painted all over. Where is the lubrication for your quill?
I've never had the toolchanger working, as I had to cut the wiring to the front control panel to get the head off. The original plan had been to unbolt the head, spin it around on the mounting boss, and bolt it on at 90deg to get under the door. However that plan quickly failed, when we realised the boss wasn't machined the way we thought it was and there was no way we were going to get it spun, so had to remove it completely. Only quick solution was to cut all the wiring to the switches, as it was soldered on with no connectors.
I was hoping you'd maybe bought some new toolholders, as I'd like to get a couple ER holders to start with. From my research, DIN2080 holders should fit, but I was hoping someone could confirm!
And for clarity, if any of the mods read this, could they split all this Shizouka talk into a seperate thread?
Help Make 1st Step - Wiring Up Drivers to Motor and Arduino
By Treemonkey in forum General ElectronicsReplies: 10Last Post: 25-04-2013, 05:47 PM -
CNC Controller with Arduino and Gamepad
By Christian Knuell in forum Electronic Project BuildingReplies: 2Last Post: 20-10-2012, 10:25 PM -
Imported L298 Arduino Modules
By boldford in forum Motor Drivers & ControllersReplies: 4Last Post: 30-07-2012, 11:06 PM -
DIY arduino CNC 2 axis table
By ruthharm84 in forum Electronic Project BuildingReplies: 5Last Post: 06-05-2012, 01:54 AM
