Thread: Wanted Linear Scale/Encoder
24-01-2013 #4
It would be easy enough to make something to convert the signal into something compatible, but the callipers response time is far too low to use for motor control, so forget that idea.
Linear encoders are generally very expensive. One cheap way to make one that should be plenty good enough to experiment with is to use a rotary encoder, put a timing pulley on it and have it run on a flat (open ended belt). Wrap the belt round the pulley with two idlers, so when the linear slide is moved it causes the pulley to rotate...I doubt it would be good enough to use in 'real life', due to small errors in the belt pitch and stretching, but worth a try I reckon.
Grey scale / height map / relief carving
By totts in forum Computer SoftwareReplies: 19Last Post: 11-08-2014, 10:47 PM -
those £55 usb bob's and those £5 tb6560 drivers pic for scale of them = tiny!!
By nobby in forum General ElectronicsReplies: 11Last Post: 01-06-2014, 04:40 PM -
NEW MEMBER: Hi,Friend,I'm a B2C seller from China for ballscrew,linear guide,linear shaft etc.
By yvesleeok in forum New Member IntroductionsReplies: 11Last Post: 10-08-2013, 11:15 AM -
Ebay 3040 issue with mach3 - incorrect scale when machining?
By Wayne Kinney in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 04-03-2012, 12:17 PM -
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM
