    Lives in East Lothian, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    It maybe makes more sense to you, but an opto with a suitable resistor (and zener if you want some extra protection) is far simpler. You can also add a capacitor across the opto if you want a simple hardware debounce.
    But anyway, why D2? If it's a solid state relay, then you don't get any surges, so it's not doing anything.
    Shouldn't R6 be connected directly to ground for quicker switching?
    Fair enough a large capacitor over the input, but 100uF for C2 seems a bit excessive.
    In fact, shouldn't R6 be tied to gnd to provide the voltage divider along with R1 and R2 for Q1?
    It all seems a bit over complicated to me.
    Thanks MC..
    I was following a design for a relay originally which suggested the resistor R2 to be here..
    It was originally for a realy, which I switched for an opto/SSR.
    I've been working on this again today with a little help from another forum.
    Not sure what value I should change up in terms of C2, any suggestions? I've changed it to a 50 for now..
    This is the updated design (as of today..).
  1. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 09:51 AM
  2. Limit Switches
    By Leadhead in forum General Electronics
    Last Post: 16-10-2013, 10:41 AM
  3. Limit Switches with LED's
    Last Post: 02-01-2013, 03:08 PM
  4. Limit switches keep activating
    By davethefixer in forum General Discussion
    Last Post: 23-09-2012, 10:12 PM
  5. Limit Switches
    Last Post: 27-06-2008, 02:21 AM
