  1. Between visitors (why does everyone turn up while you're in the middle of painting?), I managed to roller on a layer of self-etch and grey primer onto the main tray today. It looks so much better painted :)
    This evening I cleaned and rebuilt the compound slide - compare before and after :)
Name:	tray primed.jpg
ID:	258   Click image for larger version.
Name:	compound-slide before.jpg
ID:	259   Click image for larger version.
Name:	Compound slide after.jpg
    Quote Originally Posted by BillTodd View Post
    WOW, this is coming along very nicly mate, i did look at your other post and wonder if you would be doing the tray as well. Makes sense while your there huh.
    Is that really the same unit (compound slide) ? what did you use to get it up so well it looks so much better.
    awaiting the next events....
  3. Quote Originally Posted by Lee Roberts View Post
    Thanks Lee :)
    There is a degree of madness in my method - I primed the tray last so as not to bash it about while preparing the head for spraying.
    Mostly a soft wire brush, wd40 and a 'scotch-brite' buffing wheel from RDG plus the lashings of elbow grease. :)
  1. REBUILD: Hardinge HC rebuild
    By northumbrian in forum Lathe Rebuild Logs
    Last Post: 21-02-2017, 12:07 PM
  2. Hardinge KL-1
    By pauly45 in forum Conversion Build Logs
    Last Post: 18-10-2013, 07:31 PM
  3. WANTED: Hardinge hlv-h or Feeler 618
    By cookie in forum Items Wanted
    Last Post: 26-02-2011, 09:09 PM
  4. NEW MEMBER: Hardinge HLV-H Lathe
    By Roger Williams in forum New Member Introductions
    Last Post: 25-08-2009, 01:56 PM
  5. Hardinge HLV-H manuals
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 10-02-2009, 12:22 AM
