Thread: Renovating a Hardinge HLV-H
11-04-2009 #71
11-04-2009 #72
I'm just waiting for you to mention the moment of amazement and exhilaration when you move the cross feed dial .0150" in 303 stainless and find the work has reduced in diameter by .0150".
For a 45 year old lathe, that's better than looking at a new paint job any day!
Of course, I was brought up on a 1942 South Bend Heavy 10, where any relationship between the dial settings and diameter reduction in multiple materials was a complex variable that could be analyzed only through advanced calculus...:D- Mike
http://aafradio.org/
13-04-2009 #73
Updated Circuit diagrams.
17-04-2009 #74
Not much to photograph ATM, but...
I fitted a 4 jaw chuck (so I can make a backplate for a 3jc) which exacerbated the braking time problem; Essentially, the braking time for all speeds is determined by the time it takes from the highest speed, with the extra flying mass of the chuck I had to extend the brake time - I don't mind a ~6 second stop from 3000rpm, but the same from 125rpm is silly.
I emailed Siemens for advice on adding a braking resistor, to allow the VFD to brake harder, unfortunately my model VFD does not have the brake transistor fitted, so I can't do that. They were kind enough to suggest an alternative; an MM440 (@ £467), Keypad (£28), Brake resistor (£112 - expensive, even for a big resistor, I think) and a class A filter (£61). I thanked them for their help, but I won't be going down that road.
This morning I found, buried in among the 'JOG' parameters, in the Siemens VFD is an option to use the jog up/down ramp times instead of the normal ones; switching between the two settings with one of the digital inputs. A quick re-wire and now I have ~2s stop times from low speed and ~6.5s from High speed with chuck :)
It makes the whole lathe feel better. (must redo the youtube video)Last edited by BillTodd; 17-04-2009 at 06:09 PM.
17-04-2009 #75
I am blown away by the finish I can get on ally - without even trying.
A while ago, I made a fly cutter for my drill/mill from a ~3/4" stainless-steel bolt on my '37 SB 415 (9") it struggled (as you can imagine a SS bolt is very hard) but it chewed enough off to do the job. The finish was awful
In a bored moment I dialled it into the HLV chuck and took it down to 14.000mm with a couple of passes :) BIG CHEESY GRINLast edited by BillTodd; 17-04-2009 at 08:49 PM. Reason: Adding Circuit Diagram
27-04-2009 #76My goodness, I had no idea the forum requirements had such a high standard!Hello aafradio it appears that you have not posted on our forums in days !
Why not take a few moments to ask a question, help provide a solution or just engage in a conversation with other members.
Great things can come from the smallest of things !
In the spirit of the message: Bill, have you altered the spectrum of your voice in the YouTube video with a synthesizer yet? I recommend using the spectrum distribution associated with James Earl Jones' voice in the Star Wars series. Very effective....
(I think I have satisfied the unseen voices now...)- Mike
27-04-2009 #77Odd thing, but to me, I sound just like JEJ (or Richard Burton) so it must be the microphone that makes me sound like a country bumkin ;)In the spirit of the message: Bill, have you altered the spectrum of your voice in the YouTube video with a synthesizer yet? I recommend using the spectrum distribution associated with James Earl Jones' voice in the Star Wars series. Very effective....
28-04-2009 #78
I've pretty much finished the renovation now. I've just fitted the machine with castors so I can move it around the workshop until it fits somewhere.
The castors are just about man enough for the job, they'll allow me to get behind the machine and access the electrical box easily. I'll have to chock the machine with wedges once in position.
My brother gave me a nice little 80mm german(?) made chuck, so the first real job I used the lathe on was a chuck mount for the taper nose - I'll have to make myself a better boring bar though, I couldn't stop the little one I have squeaking and chattering.
13-05-2009 #79
Finally got 'round to replacing the bird's nested control circuit with a proper PCB
13-05-2009 #80
Wow bill that is some wiring mate, shop is looking good to great job and all the best in the future machining. How soon do you hope to start turning your first part ?
REBUILD: Hardinge HC rebuild
By northumbrian in forum Lathe Rebuild LogsReplies: 29Last Post: 21-02-2017, 12:07 PM -
Hardinge KL-1
By pauly45 in forum Conversion Build LogsReplies: 22Last Post: 18-10-2013, 07:31 PM -
WANTED: Hardinge hlv-h or Feeler 618
By cookie in forum Items WantedReplies: 1Last Post: 26-02-2011, 09:09 PM -
NEW MEMBER: Hardinge HLV-H Lathe
By Roger Williams in forum New Member IntroductionsReplies: 1Last Post: 25-08-2009, 01:56 PM -
Hardinge HLV-H manuals
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 10-02-2009, 12:22 AM
