Thread: Renovating a Hardinge HLV-H
28-02-2009 #11
Thanks Lee :)
There is a degree of madness in my method - I primed the tray last so as not to bash it about while preparing the head for spraying.i did look at your other post and wonder if you would be doing the tray as well. Makes sense while your there huh.
Mostly a soft wire brush, wd40 and a 'scotch-brite' buffing wheel from RDG plus the lashings of elbow grease. :)Is that really the same unit (compound slide) ? what did you use to get it up so well it looks so much better.
REBUILD: Hardinge HC rebuild
By northumbrian in forum Lathe Rebuild LogsReplies: 29Last Post: 21-02-2017, 12:07 PM -
Hardinge KL-1
By pauly45 in forum Conversion Build LogsReplies: 22Last Post: 18-10-2013, 07:31 PM -
WANTED: Hardinge hlv-h or Feeler 618
By cookie in forum Items WantedReplies: 1Last Post: 26-02-2011, 09:09 PM -
NEW MEMBER: Hardinge HLV-H Lathe
By Roger Williams in forum New Member IntroductionsReplies: 1Last Post: 25-08-2009, 01:56 PM -
Hardinge HLV-H manuals
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 10-02-2009, 12:22 AM
