  1. The spare Bijur oil metering unit arrived today from Central Surplus in the US. They turned out to be the wrong type but I was able to remove the little steel collar to replace the one I broke on my units.
    With the metering unit repaired I could replace the Oiler distribution block. This was badly corroded by coolant, so I milled it flat on all sides.
    I made a new knob for the oil pump from a cupboard door handle (I may make a better one later).
    Hopefully, tomorrow I'll have another go at spraying the tail stock and control box.
Name:	Oiler distro.jpg
ID:	296   Click image for larger version.
  1. REBUILD: Hardinge HC rebuild
    By northumbrian in forum Lathe Rebuild Logs
    Last Post: 21-02-2017, 12:07 PM
  2. Hardinge KL-1
    By pauly45 in forum Conversion Build Logs
    Last Post: 18-10-2013, 07:31 PM
  3. WANTED: Hardinge hlv-h or Feeler 618
    By cookie in forum Items Wanted
    Last Post: 26-02-2011, 09:09 PM
  4. NEW MEMBER: Hardinge HLV-H Lathe
    By Roger Williams in forum New Member Introductions
    Last Post: 25-08-2009, 01:56 PM
  5. Hardinge HLV-H manuals
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 10-02-2009, 12:22 AM
