  1. Just fitted the rewired control panel. :)
    The control logic is just a bird's nest ATM while I test it, but it seems to work as advertised.
    The photo shows the bird-nest logic and temporary 24v PSU (bottom right) I'll knock up a PCB for the two relays and PSU. I'll add a low voltage (50vac) transformer to power the work light and use (half) to power the logic.
    All I have to do now is convert the speed adjust motor to 240v...
Name:	New control panel.jpg
    Looking very Nice indeed.
    once i have finished mine, i will be doing the same type of thing.
    Good work !!
    Jon
  1. REBUILD: Hardinge HC rebuild
    By northumbrian in forum Lathe Rebuild Logs
    Last Post: 21-02-2017, 12:07 PM
  2. Hardinge KL-1
    By pauly45 in forum Conversion Build Logs
    Last Post: 18-10-2013, 07:31 PM
  3. WANTED: Hardinge hlv-h or Feeler 618
    By cookie in forum Items Wanted
    Last Post: 26-02-2011, 09:09 PM
  4. NEW MEMBER: Hardinge HLV-H Lathe
    By Roger Williams in forum New Member Introductions
    Last Post: 25-08-2009, 01:56 PM
  5. Hardinge HLV-H manuals
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 10-02-2009, 12:22 AM
