Thread: Renovating a Hardinge HLV-H
25-02-2013 #38
Hi Bill,
Thanks for such a prompt reply.
That makes a lot more sense now.
I'm assuming that the risk is that since only one phase is being used to supply all the output power, that it is the rectifier diodes on the one input that risk being over-loaded - all the output power being derived from one phase set of rectifier diodes rather than three ?
Do you just leave two of the input phases disconnected ?
Using a 3 phase 415 input VFD makes the selection choice much larger and cheaper !
Many Thanks - I'll look into 415v 3ph VFD's now !
Regards
Paul.
REBUILD: Hardinge HC rebuild
By northumbrian in forum Lathe Rebuild LogsReplies: 29Last Post: 21-02-2017, 12:07 PM -
Hardinge KL-1
By pauly45 in forum Conversion Build LogsReplies: 22Last Post: 18-10-2013, 07:31 PM -
WANTED: Hardinge hlv-h or Feeler 618
By cookie in forum Items WantedReplies: 1Last Post: 26-02-2011, 09:09 PM -
NEW MEMBER: Hardinge HLV-H Lathe
By Roger Williams in forum New Member IntroductionsReplies: 1Last Post: 25-08-2009, 01:56 PM -
Hardinge HLV-H manuals
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 10-02-2009, 12:22 AM
