    hi all this is an update of build i am in the design process stage here's what i been up to!
    the cnc base (bed) is steel constructed from 75mm, 50, & 25mm steal box
    i would like your thoughts please and weather this is up to the task?
    if anyone wants anything welding in steel from Pm a line, not to bad at welding, new 200 amp Welder on its way
ID:	8081Click image for larger version.
ID:	8082Click image for larger version.
ID:	8083Click image for larger version.
ID:	8084Click image for larger version.
    have a look
    all welcome to comment
    richard armstrong
    building 8x4 cnc all rounder, 2nd build.... major headache....LOL
    Not a bad start, but a few changes will make it a lot easier to construct and stronger. The most important factor is how do you intend to fix the box section for the bed (25mm) to the rest of the frame? It looks like it's just welded on at the moment, which makes the bed nice and strong, but the issue is with such a large Z-axis (450mm) you want to be able to adjust the height of the bed. The general idea is for sheet material you put the bed high up, so where it is in your drawing, then for the occasions where you need more Z-travel you drop it down. This is easy enough to do if you drill a series of holes in the 6 vertical pieces, support the cross pieces for the bed on two 8' long prices of box section, then attach them to the frame with M12 bolts. If that's not clear then look at my build log. You've got no chance of cutting 12mm aluminium and having 450mm Z-travel, without having an adjustable height bed.
    It'll be a lot easier to make if you use 50mm box section, or something bigger than 25mm, for the bed and use less of it. Also add in some diagonal pieces to the main frame since without them it will skew relatively easily.
    Since you want to use this for cutting aluminium, if only occasionally, I wouldn't use rack and pinion since the resolution and rigidity will be worse than with ballscres. You can easily use a ballscrew and 3Nm nema 24 motor on the 1500mm axis, however to use ballscrews on the 2500mm axis requires a large ballscrew and big motors, or rotating nuts.
    JONATHAN
    thanks for the advice and taken on board,
    i have decided to cut the z axis height down to 400mm ballscrew as the y gantry is 2x8 ali box
    decided this after i found out the you can mill sections at a time and glue together to for a fibreglass/vac form plug i think mach 3 has that ability or was it artcam????
    at a later date build a cnc router for carving vac form plugs,the later cnc 800 x 800 from ali extrusion and plate this does not have to so stiff and rigid as it only carving foam/plastics and MDF and pine
    since i posted i have modified the frame to be very rigid, see pics
ID:	8086Click image for larger version.
ID:	8087Click image for larger version.
    i know that using 50mm box would be better and save some pennis but i decied to stick to the 25mm as a way of spreading the weight and of course it looks nicer but this may change
    as for the x axis and using rack or ballscrews the jury is out on that at the mo , thanks for the spanner by the way LOL
    i will post my idea for using rack and pion and a lock plate,
    i will have that idea up soon
    speak later, buy the way i am on skype if u want to face to face pm me
    ATB
    ric
    richard armstrong
    PART TWO
    Y GANTRY IDEAS
    IDEA 1
Name:	IDEA1 y gantry.jpg
ID:	8090Click image for larger version.
Name:	IDEA1 y gantryA.jpg
    hiwin rails, nema 34 x 2, rack and pinion, aluminium plate not to sure what thickness to use or use box section and mill a lap joint, bolted and ali welded
    Idea 2
Name:	IDEA2 y gantryA.jpg
ID:	8092Click image for larger version.
Name:	IDEA2 y gantryB.jpg
ID:	8093Click image for larger version.
Name:	IDEA2 y gantryC.jpg
    hiwin rails x 2, nema 34 on spring drive plate, ali box section, rack and pin, use box section and mill a lap joint, bolted and ali welded
    Ideal 4
Name:	IDEA4 y gantryA.jpg
ID:	8095 using ballscrew and thread 20mm or more use box section and mill a lap joint, bolted and ali welded
    Idea 5
Name:	IDEA5 y gantry.jpg
ID:	8096ball screw & tread moved to bottom 2 X NEMA 34 use box section and mill a lap joint, bolted and ali welded
    this might be over engineered???????
    let me know what you think
    advice please
    ric
    richard armstrong
  1. CNC Router V1.0 (For Cutting Multiple Materials)
    By biketrialsdave in forum Gantry/Router Machines & Building
    Last Post: 05-08-2017, 03:37 PM
  2. aluminium profile for cutting bed of router
  3. Multiple CNC Opportunities both Nationally and Internationally
    By cnc jobs in forum Opportunities Available & Sought
    Last Post: 21-09-2012, 01:01 AM
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
